cam install issues
Old May 19, 2007 | 12:55 PM
87bandit's Avatar
cam install issues
just finished installing my cc503 cam but I'm running into some issues. car won't hold an idle, keeps throwing DTC code 33 (high map voltage, low vacuum), and will barely increase rpm if at all with any amount of throttle.
just wondering if anyone had any ideas what it could be, I made sure the valve lash was perfect as well, redid it twice with zero changes
Old May 19, 2007 | 01:09 PM
seawolf06's Avatar
Might have to try a new map sensor. What's it reading when it tries to idle? Should be about 1/3 of the BAR which is around 30 at sea level.
Is it popping or backfiring at all? Did you make sure to line the timing chain up right?
Check all your wiring and connections again.
Old May 19, 2007 | 01:46 PM
87bandit's Avatar
yes it was popping and backfiring under any amount of throttle
by lining up the timing chain I assume you mean the timing set in general?
Old May 19, 2007 | 02:02 PM
seawolf06's Avatar
Making sure the sprockets were dot to dot and all that jazz. Did you use shoebox's guide? It's very comprehensive.
Recheck all your plug wires. That was my problem, but you have to fix that code first. It can be thrown with some cams, but the 503 isn't that big. Check all your vacuum lines as well as the EVAP.
Old May 19, 2007 | 02:46 PM
2000GTP's Avatar
Its common for the connectors for the MAP sensor to dry out and crumble, might be worth a shot to check that out too.
Old May 19, 2007 | 04:05 PM
ricehammer's Avatar
I just put heads and a 503 in my Z and it did the same thing. No throttle response and backfiring when I tried to crack the throttle. Got a new program from PCMforless and it runs like a champ.
Old May 21, 2007 | 12:03 AM
87bandit's Avatar
turns out cam itself wasn't installed 100%, fixed it today and runs like a champ
Old May 21, 2007 | 12:50 AM
sandman63's Avatar
What was the actual problem?
Old May 21, 2007 | 01:05 AM
JP95ZM6's Avatar
The old 'off 1 tooth' I'm betting....
Old May 21, 2007 | 01:06 AM
87bandit's Avatar
didn't line the dots on the sprockets up completely, I trusted my friend to reinstall the cam itself
Old May 21, 2007 | 01:07 AM
87bandit's Avatar
just gotta redo the valve lash, a rocker or two seem kinda loose.
Old May 21, 2007 | 06:55 AM
Yeah, the MAP code was a result of the problem, not the cause.
Old May 21, 2007 | 10:21 AM
87bandit's Avatar
oh yeah thanks for the help shoebox, site was very helpful
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
