Cam install Help Please!
I have decided to change out the cam I put in last year, my question is that I put the number one piston on TDC on the compression stroke, and pulled everything apart just like last year.
Then I find that the dots on the sprokets are nowhere near each other once I pulled the timing cover off. The lower gear on the crank has the dot pointing straight up like it's supposed to, yet the top gear the dot is like at 1:00, can someone explain what I have done here, the car ran fine for the last year with the cam just wondering what I could of done. Also what happens if you put the cam in on the exhaust stroke.
...Rich
...Rich
Originally posted by PoorMan
I think TDC#1 is 12 oclock and 12 oclock. It may be 6 oclock and 6 oclock though, I forgot. It's one of the two. I am pretty sure dot to dot is TDC#6
Jeff D.
Jeff D.
OK so why do we put the large cam gear at 6 o'clock and the small crank sprocket at 12 o'clock )in other words dot to dot)when we put everythihng back together. acording to the haynes manual i'm looking at, they show the dots together upon removal and installation and they say TDC on the compression stroke is where the motor is set at.
hth
What he said
The dot to dot way is the easiest way to get the timing correct because the line between the two is shorter. You are just trying to get the crank and cam in "time" with each other. It would be harder to line up the dots both at 12 o'clock but you can do it that way too. The whole thing about TDC at whatever cylinder really only matters when you are installing your rocker arms. This is because we use a non-adjustable timing set.
You can see from the 2 pics I have with the heads off that #6 and #1 are both pretty much at the top. Not sure about this but I think dot to dot = #6 TDC compression stroke and #1 TDC exhaust stroke. When most people say TDC in general they usually refer to compression stroke but some use it for both and I think this causes some confusion.
Jeff D.
The dot to dot way is the easiest way to get the timing correct because the line between the two is shorter. You are just trying to get the crank and cam in "time" with each other. It would be harder to line up the dots both at 12 o'clock but you can do it that way too. The whole thing about TDC at whatever cylinder really only matters when you are installing your rocker arms. This is because we use a non-adjustable timing set.You can see from the 2 pics I have with the heads off that #6 and #1 are both pretty much at the top. Not sure about this but I think dot to dot = #6 TDC compression stroke and #1 TDC exhaust stroke. When most people say TDC in general they usually refer to compression stroke but some use it for both and I think this causes some confusion.
Jeff D.
Rico, the pic in the book is confusing or even wrong (I dont have mine in front of me) but 12/12 is TDC #1 compression stroke. Mine is apart right now and when I put it back together it will be 12/12 to the besti of my eyeball ability but I will spin the assembly 1 turn (when adjusting the rockers) and verify the 6/12 is lined up also. Hope that helps.
F(ast)-body
Feb 26, 2003 09:05 AM
