cam install
cam install
I really want a cam,but I don't think I can install it it myself.I don't have a hoist or other kinds of tools I probably need.I was wondering what can I expect to pay a shop to do it,or If a guy at work did it.Just a estimate,and If you guys had it done,what were you charged.Do you prefer a specific cam.
What do you need a hoist for? You can install a cam with the engine in the car. Y ou will have to remove the radiator and move the a/c condesor out of the way. You really don't need many specialized tools other than a harmonic balancer puller and a torque wrench. Just buy a good manual and take your time. The experience will be good for you. Most places will rape you in labor. I've seen between $500-1000 for cam installs. Find a buddy or someone here on this list to help you. You might get away with pizza and a 6 pack to help you. As per cam choice, that depends entirely what your expectations are and what you want out of it. If you want a cam for more power but still use it as a daily driver, get an LT4 hot cam or CC305. If you want a nasty 1/4 cam, go with a XE grind or CC306 (I have a 306 and it is the largest cam I would use personally for a daily driver). Good luck.
Once you get the radiator out of the way, you can install the cam. Some people remove the hood latch, but you actually dont need to, although I had my dowell pulled out (vice grips) and used a little bit of angle, just make sure you dont mark up your bearings while doing so, so go slow and carefull.
F(ast)-body
Feb 26, 2003 09:05 AM
