Cam Install
Cam Install
Ok, after seeing a members results with stock heads and the CC306, I think I want to go with this cam. I assume I will need lifters, valvesprings, and roller rockers. Which of those items would you recommend? Anything I could buy from GM, that would be a great because I can get a discount. I think I can get 1.6 RR and the valvesprings from GM... anyone know the part numbers? Do I need to replace the lifters and pushrods on it? It has 80k miles... I would assume it would be a good idea.. Thanks for the help.
-Eric
-Eric
Re: Cam Install
Re: Cam Install
cc306 is made by comp and the duration is
230/244
The GM847 is made by crane and the duration is
232/242 i believe.
I'm sure the lifts are diff but the duration is what will affect emissions and driveablity.
230/244
232/242 i believe.
F(ast)-body
Feb 26, 2003 09:05 AM
