cam iinstall
Old Jun 5, 2007 | 06:50 PM
93camarochrisz28's Avatar
cam iinstall
how do you install the bearings for the cam and how to you check the gap
Old Jun 5, 2007 | 07:26 PM
Boosted_Z28's Avatar
Not the easiest procedure to try to explain...maybe this link would help you:
http://www.aptfast.com/Flyer_HowTo_D...ambearings.htm
Old Jun 5, 2007 | 07:37 PM
JAKEJR's Avatar
Most of the cam companies tech info on this simply says to take the block to a machine shop.
Installing them calls for using a special tool, which most don't have in their tool chest, nor the mics to do the measurements.
The upside is cam bearings rarely fail. About the only time they do is caused by improper camshaft installation when one (or more) of the bearings is gouged during cam installation.
Jake
Old Jun 5, 2007 | 07:41 PM
thanks alot
Old Jun 5, 2007 | 08:38 PM
JAKEJR's Avatar
Originally Posted by 93camarochrisz28
thanks alot
Also, because of the length of the installation tool the block has to be out of the car to install them.
Jake
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
