cam id numbers
Old Nov 22, 2005 | 08:20 PM
Foxls1's Avatar
cam id numbers
did i get the right cam? supposed to be a hot cam but just double checking,
586-wb23
323-98L those are the mubers on the end of the cam???
also do lt4 springs have a dampener AND an inner spring??
Old Nov 23, 2005 | 03:07 AM
sssalah's Avatar
Re: cam id numbers
Can't answer the cam id as my hotcam was long sold. The LT4 springs are single without dampner.
Old Nov 23, 2005 | 06:36 AM
Foxls1's Avatar
Re: cam id numbers
comp 977 - 16 is the part number on the box, these springs have a dampener and an inner spring. how would i be able to confirm this
Old Nov 24, 2005 | 06:14 AM
Mtrhds94Z's Avatar
Re: cam id numbers
586-wb23
'586' is the last 3 #'s of 24502586 which is the LT4 hot cam p/n... the other #'s are run #'s etc..so yes, it is a hotcam..
Old Nov 24, 2005 | 08:35 AM
brubble's Avatar
Re: cam id numbers
The 977 where the springs I put in my car. I just used the boxed to ship you the springs.
Old Nov 24, 2005 | 10:16 AM
Foxls1's Avatar
Re: cam id numbers
the springs i got tho were double springs with a dampener, if the
lt4 springs are single then what springs are these? lol im not griping about it i just want to know if i can uses em, if so ill put the 918s i just bought on my
ls1........
Old Nov 24, 2005 | 04:26 PM
brubble's Avatar
Re: cam id numbers
I know the 977 where to big (wider) for the lt4 rockers thats why I had to replace them with the comp mags. those springs the cam and lt4 rocker all came out of the car at the same time. I would mic them as long as the are the same diameter they will work.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
parkers Z28
Mar 11, 2016 08:14 PM
grabbem88
Feb 22, 2015 11:16 AM
