cam help plz look
Old Apr 4, 2011 | 09:33 PM
  #16
vangill's Avatar
Re: cam help plz look
Due to all your stipulations u have plaed on yourself u need to call the companies and ask them specifically. Especially since ur in a bind. But bc of your time constraints I would say your best decision would be to quit trying to piece the car together like a puzzle and do it right, especially if it really is a show car like u say u r gonna want it well put together not a puzzled conglomeration of super cheap parts
Old Apr 5, 2011 | 12:03 PM
  #17
DTRJAR's Avatar
still need a cam for this setup thanks
Old Apr 5, 2011 | 12:14 PM
  #18
red94chicken's Avatar
you are looking at flat tappet cams you will want a hydraulic roller cam and some real springs. stop trying to cheap out. read more and learn things before you buy.
Old Apr 5, 2011 | 02:29 PM
  #19
bw_hunter's Avatar
Mr DTRJAR,
There likely isn't anyone that is going to tell you to use a certain cam and that it will work with everything you just bought. No one can be sure if the pushrods you bought will work and won't tell you they will. Just sayin'
I said it once before, the comp cams 304 will probably work with your springs and rockers. I don't know about the pushrods...they're probably too short.
If that isn't good enough for you, maybe you should consider throwing the stock stuff back in, selling the stuff you bought and starting over.....
Old Apr 5, 2011 | 03:07 PM
  #20
DTRJAR's Avatar
ill buy the 304 and then if i have to ill buy new pushrods thanks
Old Apr 5, 2011 | 07:39 PM
  #21
RamAir95TA's Avatar
This is a perfect example of how not to do things.
Old Apr 5, 2011 | 10:02 PM
  #22
DTRJAR's Avatar
Ya tell me about it
rideordie
Nov 5, 2019 04:52 PM
mattszm6
Dec 14, 2014 07:09 AM
Elcojoe
Nov 17, 2014 10:27 PM
