cam help plz look
cam help plz look
will this cam http://cgi.ebay.com/ebaymotors/Sbc-L...Q5fAccessories
work with all this or what did i still need thanks
COMP Cams 503-16 TEFLON VALVE STEM OIL SEALS 11/32"
COMP Cams HI ENERGY PUSHRODS 5/16" x 7.195" SBC LT1
ARP SB CHEVY BLACK OXCIDED 7/16' ROCKER ARM STUD KIT
GM Performance Pushrod Guideplate 14011051
https://www.camaroz28.com/forums/sho...d.php?t=805611
VALVE SPRING KIT, LT1 .600 LIFT DROP IN FIT, LT4 SBC
need help fast i have most of the stuff on the way now i need a cam or if some one could tell me a cam to go with thanks
Re: cam help plz look
COMP CAMS LT1-LT4 BEEHIVE VALVE SPRINGS KIT .625" LIFT
Maybe you should tell us your gopals and we'll help on the cam. Chances are, however, that some of that stuff is going back...starting with the pushrods.
You made a few mistakes. Buying all of that stuff ahead of time is a pretty poor plan of attack. You ordered shorter pushrods but you need to measure for proper geometry. They may work, they may not. I suggest sending it all back and doing some research because you're obviously (no disrespect intended) unsure of what you're doing as of yet. There's a ton of info online on this forum and others, enough for you to make an informed decision.
can some one PLZ tell me a cam that WILL WORK with whit i have here PLZ i got all this stuff off here and ebay so i cant just take it back ya i F**Ked up trying to do tomuch a one time lol PLZ some one help me OUT here THANKS
You list nothing about the valve springs. No one can tell you what cam will work without their exact specifications.
And the pushrods you'll have to measure for. You might get lucky with the ones you purchased - you might not.
OD: 1.268"
Average Coil Bind: 1.135"
130 Lbs @ 1.790"<-- valve closed pressure
330 Lbs @ .500" Lift
345 Lbs @ .550" Lift
360 Lbs @ .600" lift
Made in the USA.
Works with many hi performance hydraulic roller cams.
For use all the way up to 244 degrees duration @ .050" with up to .600" Lift @ the valve.
OD: 1.268"
Made in the USA.
will this one here work http://cgi.ebay.com/ebaymotors/COMP-...Q5fAccessories
