Cam help please
Old Jun 30, 2007 | 05:31 AM
96vortechSS's Avatar
Cam help please
I'm not sure if you'll be able to help me for sure or not but I'll give you as much information as I can. The build is a 396 cid with a set of Canfield 220cc heads that flow 275cfm @ .400, .290cfm @.500, 303cfm @ .600, 312cfm @.650, and 317cfm @ .700. The .700 lift number is really irrelevant because the springs are only setup for .650 lift. I'm probably going to run somewhere around .620 lift. This is a max hp effort so I will be running a SR cam. My question is what duration do I need to run in order for the horsepower to peak at 7000rpm with this cubic inch and size head.
Old Jun 30, 2007 | 08:36 AM
rskrause's Avatar
Moderator
~250-255 degrees @ 0.050"on the intake side. The LSA will also have an effect.
Rich
Old Jun 30, 2007 | 02:59 PM
I was planning on running a 117 lsa since it is a turbo application. Maybe a 116 lsa. What do you think? Does a wider lsa increase the rpm or decrease the rpm power band of a cam?
Thank you for the reply Rich.
Old Jun 30, 2007 | 07:53 PM
rskrause's Avatar
Moderator
LSA will make very little difference in the rpm band with a turbo.
Rich
Old Jun 30, 2007 | 08:01 PM
speed_demon24's Avatar
I would just contact a cam grinder and have them spec you out a cam.
Old Jul 9, 2007 | 10:32 PM
Rich
Typically what does closing the LSA do to powerband of a cam on a N/A setup?
Take a 224/230 xtreme engergy as an example if it has a 6200 rpm redline with the 112 lsa what would a 110lsa do to that cam?
Old Jul 9, 2007 | 10:35 PM
maro z28's Avatar
generally speaking, a more narrow LSA will increase overlap. This will generally push the rpm band up slightly.
Old Jul 10, 2007 | 06:30 PM
Excuse me for asking but how much rpm is slightly 200 rpm, 400rpm?
Old Jul 10, 2007 | 10:02 PM
maro z28's Avatar
How much? I don't have that info on me. I'm sure its different for different engines. Maybe Rich or Fred have that info.
Old Jul 11, 2007 | 01:45 AM
Right, I'm sure cubic inches and runner size of the heads plays a role in how much increase in rpm will be seen. This question is for a kid at work whom is kinda making me crazy. I've told him to go with an AI h/c combo and he'll be happier but then he just gives me the impression he really just wants a really choppy idle. So if he doesn't do the heads (big mistake on his part) I've picked lobe # 3014 for his intake and lobe # 3035. I was also thinking about lobe #3190 for the intake but didn't really want to split the durations by 10 degrees. All of these ground with a 110 lsa and 4 degrees advance ground in. Along with a pcm tune of course. I figure this will give him the sound he wants without going past 6200 rpm.
Old Jul 11, 2007 | 02:06 AM
thesoundandthefury's Avatar
The width of the powerband doesn't increase or decrease with LSA changes, it just moves up or down in the rpm range. A higher LSA will have less overlap and will move the start of the powerband down, but also fall off earlier. A lower LSA will move the start of the powerband up, and fall off later. The catch-22 in your situation is that you're running a turbo in an engine with high piston speed, so it's going to be tricky coming up with a cam that'll allow the engine to breathe in the range it wants to without wasting too much boost out the exhaust valve because of overlap.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
