cam/head stock bottom A4 runs 11.63 on drag radials
Originally posted by T/A lt1
I haven't dynoed but my car has alot more than 117mph in it. You talk about rwhp Franks car made 330rwhp and he runs 11.40@116mph then Sar2k made 450rwhp and ran 11.40's@117mph on the same day Frank ran 11.50's@115mph thats a 120rwhp difference and the et's are almost the same? so it really doesn't have much to do with dyno #'s but my example was your car ran 113mph and my car ran 117mph first time at the track spinning in the 60'. Stick some ET streets on your car and you will lose some mph I can tell you that much. I am still running 3.42's so there is also some mph in the gearing but I won't change b/c my goal is to run 128-130mph on a 200shot then that will be another story but it will happen very soon. Ken's95 isn't running but 11.60's @117mph and with very good track conditions he ran some 11.40's@117mph in La, and he dynoed 384rwhp so what does that mean? Every dyno will be a little different so comparing dyno#'s means zero and comparing trap speeds between auto's doesn't mean too much either b/c converters eat HP but the final ET is what counts b/c thats who wins. So my car had some 11.40's with some better traction but now it will run 11.20's with a new setup. Later Clint
KEn's car 384 rwhp and 11.6 @ 117 (adds up )
Joe's camed cars 420+ rwhp (on special dynos) trap 117mph
My whole point is Joe is not specing a cam any better that say cam motion which alot of people swear by. you guys are putting him on a pedistal. i have a few cars that i have done that run well also but you don't hear them guys on here bragging about their cars.
Altajar your name keeps getting brought up b/c you are talking bad about cars that run quite a bit quicker ET and mph than you are so when you get your car to run quick faster than 11.99-12.00 then you may be able to talk about the slower cars
Saints Franks car weighs 3100lbs or so and Sar2k weighed 3400+ but we are talking 120rwhp difference so by you guys math Steve should be running 125mph or so but he only runs 118mph. With a M6 that is geared correctly you can tell alot by the mph but with an auto it's a little different b/c we are trying to ET not MPH. An M6 will always trap higher than it can actually ET unless it is a clutchless Lenco but not no GM T56. I am thru with this topic just bring your cars down for the next Thunder Shootout and you will see where the HP lies.
Seems like just yesterday this post was only one page long,,,, oh wait,,,, that was yesterday..
C'mon guys, let it rest. I'm sure once the bugs are worked out of Joe's cammed car, it'll run harder. Until then, just sit back and relax. It is an Automatic, maybe he's getting slippage in the top gears. Haven't you guys ever gone to the track and been disapointed with the results because of something not quite right? Slipping clutch, bad track prep etc..? One time at the strip doesn't really say what the car is really capable of.
BTW guys, Chris Benight's Z28 was running mid 11's @ 119ish 3 or 4 years ago with a cc306 and ported LT4's, for those that were around here back then. I believe he was pushing 410rwhp through an M6 if memory serves.
Mike
Mike
You know it seems to me that their is a concept that HP and ET are some sort of linear equation. With that logic top fuel cars would be finishing the quarter before they started. The problem is nobody but the driver would know he made a run because in the resulting time warp the crowd would all have grown old and died. But the real question is if the driver had his headlights on would he have been able to see them?
For gods sake STOP talking about the ET. No one is saying anything bad about that. You can run a 11.6 at 117 fine and dandy. You dont run a 117 trap with a 420 hurse car.
Any idiot knows ET is based as much on chassis and traction as it is power.
Did you guys ever stop to think that maybe the problem is with the driver and not the cam and heads combo?
I put out 378rwhp & 390lb.ft of torque running rich.
I ran 13.0@108mph (13.1@110mph on a Gtech) doing a burnout down the track 2 yrs ago lol.
Since then I've improved my 1/4 mile times getting them down to 11.82@115mph on a G-tech. Nothing has changed in the motor. I've just become a better driver.
I'm sure if I went to the track this year I'd do even better.
There are too many factors that affect 1/4 mile times. XXX RWHP is not going to = XX.XX@XXXmph
'03 Cobras put out 370rwhp but only run 12.8@112mph.
Also the faster you go, the more hp it takes to make a difference in your ET.
If you already go 120mph, adding 300hp is NOT going to give you a 150mph trap.
show me the NHRA/IHRA correction factor for a certain HP mandates a certain mph.
Oh,and 2muchpsi,the dyno we used was perfectly fine,we just do a baseline tune on the dyno and dial it in at the track for varying weather condition's. We use Second Street Speed's (same shop that does all of Baxters work,and set up Injuneer's car) it is a Dynojet and it will read higher then a mustang or other brake type dyno's.
Makes good power and I was surprised at the driveability, brakes are fine, and my idle is acceptable. I'm currently running it on a tune meant for a CC305 slow it's slightly rich, like enough to make my eyes water when I stand behind my car. Lots of potential and I'll know for sure in a couple of weeks at the Georgia F-body shootout up in Reynolds.
PS. Of course I just bought a stroker block today.
That was the post of the day. If my sig wasn't so big it would become a quote in there.
You didn't know tha 420hurses always equals 120mph! It must be the extra hurses that do it in any weight,gear tranny even in an Impala SS if you have 420hurses it should run 120mph according to Altajars calculator.
