Cam Grease?
Old Sep 4, 2005 | 02:20 PM
96trans am's Avatar
Cam Grease?
I am currently re-building my top end, Heads/ Cam etc. I bought a Joe O cam and it didnt come with any type of cam grease. In the manual it recommends you grease up the cam before installing. Is it a big deal of what grease I buy, and do i even need to do it? Thanks for the info. -Matt
Old Sep 4, 2005 | 02:53 PM
swemdog's Avatar
Re: Cam Grease?
This is definitely something you should do. The grease is to keep the cam lubed until oil reaches the cam journals/lobes. You should be able to buy some at the parts store. I used engine assembly lubricant the first cam I did.
I know ARP makes some too, I have used that also.
Edit- Just did a search and some people use gear oil, and some use engine oil. Do a search it will tell you more.
Old Sep 4, 2005 | 05:36 PM
MachinistOne's Avatar
Re: Cam Grease?
I use Sta-lube black graphite moly lube. Also the Permatex engine assembly lube is good, nice and sticky.
ShwaZedder
Apr 9, 2015 06:33 AM
PublicEnemy1
Apr 7, 2015 12:21 PM
squarehead
Jan 15, 2015 07:02 PM
Hurin
Dec 13, 2014 07:38 PM
Duke
Aug 6, 2002 07:53 PM
