Cam Dowl Question
Old Oct 5, 2005 | 06:03 AM
z96's Avatar
z96
Cam Dowl Question
Putting My New Opti On My New 383 Build Up (first Time) My Machine Shop Told Me When Installing Opti Not To Force On I Can Tap Dowl In Little By Little To Opti Fits Flush To Front Cover. Is It Poss To Tap In To Far (my Is Sticking Out About A 1/8 Inch Past Cam Bolts Now And Opti Fits Perfect. Is That A Timming Refrence And Bolts Actually Run Opti Or Does The Dowl Spin The Opti. Thanks In Advance For All Help
Also This Is A 97 Vented Opti
Old Oct 5, 2005 | 07:20 AM
Re: Cam Dowl Question
The dowel pin turns the opti. If not sticking out far enough, it's not going to work. You need to measure the length of the pin from the face of the cam. It should be in the .620-.685 range. My stock cam's pin was .650".
BTW, why do you capitalize every word? It makes it hard to read.
Old Oct 5, 2005 | 10:17 AM
z96's Avatar
z96
how do i measure the length of the dowl. what tool do i use? what if it is
in to far how do i pull it out?
Old Oct 5, 2005 | 07:50 PM
z96's Avatar
z96
ttt measured dowl and it in to far 3.05 only sticking out from face of cam how can i pull it out
Old Oct 6, 2005 | 06:36 AM
Jeff95TA's Avatar
Probably best to take it to a machine shop.
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
