cam change
Old Sep 1, 2003 | 12:08 AM
Bandit97's Avatar
cam change
I dont have a lot of cash to be spending on heads and cam, so can i expect much gain out of doing a cam swap as far as hp and track times, and what is the best cam to go with on a stock 97 ta that will not require a lot of changing other stuff other than maybe springs? And what would I be looking at in cost for cam and decent springs?
Old Sep 1, 2003 | 01:25 AM
RedPhenx's Avatar
it really wouldnt be worth the time or effort to change the cam if you dont want to do a lot, at the very least you would have to go with new springs, a cam is about 250 for most any grind and springs etc are about 150, though if you still have stock manifolds you wont get as big of a jump.. best think to do would be to get headers and keep cam stock for now
Old Sep 1, 2003 | 05:35 PM
magnumv8's Avatar
Alot of guys are using the Hot cam kit with stock heads. I think you can get the kit for less than $500 and you would definately see power gains without HAVING to change a lot of other things.
Old Sep 2, 2003 | 12:02 PM
96blackbeast's Avatar
cc305 is a better cam than the hotcam, or call cam motions and get a custom grind.
IgorT.455/406
Mar 12, 2015 03:39 AM
blac94Z
Feb 18, 2015 11:36 AM
InfernalVortex
Jan 17, 2015 09:35 AM
birdblack
Dec 30, 2014 06:59 PM
