The cam is in but have a question?
Old Feb 18, 2006 | 04:23 PM
Nick-LT1's Avatar
I just put a cc306 with 1.6 rr ect well the car runs great pulls great idle is awsome. The only thing is when at WOT it smokes quiet a bit? What could that be? I know that there is some oil the headers but it smoked ALOT at wot? Sould i be worried? Thanks!
Old Feb 18, 2006 | 04:29 PM
TheNuge876's Avatar
Re: The cam is in but have a question?
did you break it in first??
Old Feb 18, 2006 | 04:32 PM
Kreinmc's Avatar
What does he need to break in? Hydraulic rollers do not require a break in! I would guess that you have some bad valve seals. Did you replace them with new ones? Or did you reuse the stockers?
Old Feb 18, 2006 | 04:34 PM
Cmr0z28's Avatar
Mine smoked for a good 30-35 mins because of all the crap on the headers. After that, no more smoke. Is the car tuned? Are you sure it's oil and not fuel?
GMRL's Avatar
Smoking from where? Under the hood or exhaust?
How many miles have you put on it since the install?
Old Feb 18, 2006 | 04:47 PM
runlt1z28jake's Avatar
What spring setup/rr's was installed? Also what other changes did you make? Check oil till a problem is found.
Wckd94Z's Avatar
I'm pretty sure if it was fuel, it would be a lot more exciting than just smoke . i imagine he is the one driving, so if he can see the smoke it's probably coming from under the hood.
Old Feb 18, 2006 | 05:44 PM
Smoke smells like rubber burning and is visable from rear tires at wot.
Old Feb 19, 2006 | 12:31 AM
MeanGreen97Z's Avatar
I would bet to say you ripped the original valve seals if you didnt replace them. Maybe running rich. I had that problem with my cam before tuning.
Old Feb 19, 2006 | 12:37 AM
Z95m6's Avatar
Also your intake might not of sealed right at the intake ports so it sucks oil, and it would be more obvious at WOT.
Old Feb 19, 2006 | 01:44 AM
Nick-LT1's Avatar
Talked with they guy that did it all and it probably is valve seals. I cant wait to spend more money on this thing!!!!
Old Feb 19, 2006 | 03:40 AM
RedLT4Mike's Avatar
Yeah, I'd say valve seals.
"Guy who did it" should have had enough sense to do the
valve seals too, unless you instructed him otherwise.
You may want to find another "guy".
Old Feb 19, 2006 | 03:59 AM
Ya valve seals are cheap and easy to install. If he charges you more then 70-80$ he is blowing smoke up your ***.
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
