cam break in, how long?
Old Dec 5, 2007 | 11:33 PM
sn8ke eatr's Avatar
Im in the process of putting a new comp cc305 cam in my car. the bottom end is still untouched. my question is how long would you guys reccomend i take it easy on the motor till the cam is "broken in" enough to run WOT?
also, i will be having a mail-ordered tune made for my car, along with larger injectors. it wouldnt do any harm in starting the car with the stock tune still on would it?, it would only be for a short time to make sure everything is working correctly. thanks for any help,
Old Dec 5, 2007 | 11:34 PM
userchemical's Avatar
im pretty sure you dont have a break in period. and yes you can start your car, the cam isnt that big, you will just be down on power and running like ***.
Old Dec 6, 2007 | 12:04 AM
A number of heat/cool cycles is good for a new valvetrain, but the cam, itself, needs no special break-in.
Old Dec 6, 2007 | 04:05 AM
rskrause's Avatar
Moderator
When I build a new motor we start it up and warm it to full operating temp while watching closely for any leaks, funny sounds, etc. Usually run it runs for 5-10 minutes on the chassis dyno under low load, but no load is ok also. Then shut down, let it cool, recheck things like valve adjustment, head bolt torque, etc. as appropriate for the type of build. After that, beat it like a red headed step child.
Rich
Old Dec 6, 2007 | 07:23 AM
SS RRR's Avatar
Because it's just a cam swap and as already stated there is no break in procedure. I've done cam swaps where I start it, let the oil circulate through the engine at a low rpm, shut the engine off and change the oil.. or change the oil, start it, let it run for a few minutes and then change the oil again to make sure all gunk from the engine being open has been washed out. Naturally you should make doubly sure to do the cleanest install you can since the front of the oil pan is exposed and can catch all kinds of nasty **** as well as keeping the oil valley clean.
Old Dec 6, 2007 | 09:40 AM
rskrause's Avatar
Moderator
Yeah, as SS RRR reminded me: after the inital warmup/run in I do change the oil.
Rich
Old Dec 6, 2007 | 11:37 AM
marshall93z's Avatar
I was wondering about that!
Old Dec 6, 2007 | 12:55 PM
sn8ke eatr's Avatar
sounds good. let the beating commence shortly
AdsoYo
May 2, 2018 03:21 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmyname1
Feb 19, 2015 08:38 PM
