Cam bearing rant!!!
Old Oct 14, 2007 | 05:19 AM
  #46
rskrause's Avatar
Moderator
Originally Posted by marshall93z
Problems?
You can score/nick the cam bore if you get rough.
Rich
Old Oct 14, 2007 | 11:10 AM
  #47
marshall93z's Avatar
Gotcha.
Old Oct 28, 2007 | 04:00 PM
  #48
Ok, finally getting around to putting these things in. Machine shop had them all installed with the holes at 6 o'clock, with the first one's two holes being ~2:30 and 6 o'clock.
Everything I have read, people are saying ALL KINDS of different thing about how to clock them.
Clevite has this to say:
Originally Posted by Clevite
On blocks without grooves behind the cam bearings, care must be taken to insure that oil holes line up between the bearings and block. Where the block has a groove behind the bearing(which this block does), the bearing should be installed with the oil hole at the 2 o'clock position when viewed from the front for normal clockwise camshaft rotation. This will introduce oil into the clearance space outside of the loaded area and allow shaft rotation to build an oil film ahead of the load.
So should I put them where there were, from the machine shop, or follow Clevites suggestions?
Old Oct 28, 2007 | 04:22 PM
  #49
Ah hell, I think I'll just go with what Clevite said. They have to know more about bearings than my engine builder does!
And since NONE of the stuff I have read the pros saying is agreeing on what my builder did(6 o'clock), that is just more reason to go with Clevite.
It really seems to be a non-issue anyway, with no adverse effects....no matter HOW you clock them.
Old Oct 28, 2007 | 09:27 PM
  #50
Well, I got 'em all in there. Wasn't hard at all. Cam spins pretty freely, so I guess I didn't mess anything up TOO bad!
Although it did look like I saw some polished looking spots on the bearings after i took the cam out. And these are black(coated) bearings, so I don't know WHY they would be shiny. I'll look again tomorrow in better light.
Old Oct 28, 2007 | 09:46 PM
  #51
Kevin Blown 95 TA's Avatar
Regarding the shiny spots you mentioned...
Originally Posted by rskrause
... If there is a tight spot you should see a shiny spot on the bearing after turning the cam over a few times. You can carefully remove it with a bearing scraper. Just be sure the high spot is not from any debris caught under the bearing shell or scoring in the bearing bore from you ham handed attempts to remove the prior bearings.
Rich
Old Oct 29, 2007 | 11:52 PM
  #52
Yeah......
How big of an issure are the shiny spots?
Old Oct 30, 2007 | 04:58 AM
  #53
Are they real tiny?
Old Oct 30, 2007 | 05:10 AM
  #54
rskrause's Avatar
Moderator
If it turns real easy it shouldn't be a problem.
Rich
Old Oct 30, 2007 | 08:49 AM
  #55
Originally Posted by Kevin Blown 95 TA
Are they real tiny?
Not really. Maybe 1/2-3/4" long and maybe an 1/8 inch wide.
I'll try to get a good picture of them today,
Old Oct 30, 2007 | 08:52 AM
  #56
Rich
I can grab the dowel and spin the cam round and round with very little effort.
Old Oct 30, 2007 | 08:56 AM
  #57
mdacton's Avatar
sounds like they are crooked...is the 1/8" spot on one side or in the middle?
Old Oct 30, 2007 | 09:14 AM
  #58
It's not on the very edge, but it's not dead center either. I'll have to go look at them again to make sure.
Old Oct 30, 2007 | 11:02 AM
  #59
If I DO find one that is cocked, can I knock it out and reinstall it? Or are they junk once you knock 'em out?
Old Oct 30, 2007 | 11:29 AM
  #60
I don't know about all cam bearing tools, but the one I used has the big collar that goes in the bore to center the shaft. You'd THINK that would allow you to get them in there straight!
http://www.amazon.com/ATD-Tools-Univ.../dp/B00061SIMU
carl.froehlich
Mar 13, 2015 12:38 AM
StansZ28
Feb 19, 2015 07:39 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
