Cam bearing rant!!!
Old Oct 6, 2007 | 01:31 PM
  #31
marshall93z's Avatar
Cool, thanks!
I figured Clevite would have good cam bearings since their others are so highly thought of!
Old Oct 6, 2007 | 04:00 PM
  #32
rob97ss's Avatar
Why the`9 months delay for cam bearing?
Old Oct 7, 2007 | 12:36 PM
  #33
Have been really busy and haven't had time to mess with it. Just now starting to get some free time.
Old Oct 7, 2007 | 01:03 PM
  #34
raroz28's Avatar
you took it from the shop and had it for days. They're going to assume you attempted to put the cam in, gouged it up, and are trying to get them to put new ones in for you at their expense.
I always fully inspect everything from the machine shop before I walk out with it.
I'd be surprised if they do anything for you.
Old Oct 7, 2007 | 02:43 PM
  #35
You must have misread the thread. I took it back to them as soon as i saw them, like the next day, or something. THEY told me that THEY put a cam in...is where the marks are from.
Old Oct 13, 2007 | 11:13 AM
  #36
Originally Posted by 1racerdude
I almost ordered that, but then noticed it isn't for a 350!
Anyway...a friend of mine has a cam bearing tool, so I'm gonna get the good bearings and do it my damn self.
Old Oct 13, 2007 | 11:27 AM
  #37
1racerdude's Avatar
That was only an example of brand.
Look up the ones for an LT1 they make them.
Old Oct 13, 2007 | 11:46 AM
  #38
I did, thanks! It is the 8T. I hope!
http://store.summitracing.com/partde...T&autoview=sku
Old Oct 13, 2007 | 11:58 AM
  #39
1racerdude's Avatar
That looks like them.
Make SURE ya clock them right when installing.
Old Oct 13, 2007 | 12:03 PM
  #40
Yep!
I guess that could introduce a SMALL oiling problem?
Old Oct 13, 2007 | 12:14 PM
  #41
1racerdude's Avatar
Old Oct 13, 2007 | 12:48 PM
  #42
rskrause's Avatar
Moderator
It's harder to install cam bearings right than it look. It is very easy to get them "cocked" in the bore. Be sure to test fit the cam by lubing it up, inserting it, and rotating it. It should turn VERY easily even with no oil pressure. If it does not turn easily, it is either because a bearing is cocked or there is a small "high spot". If there is a tight spot you should see a shiny spot on the bearing after turning the cam over a few times. You can carefully remove it with a bearing scraper. Just be sure the high spot is not from any debris caught under the bearing shell or scoring in the bearing bore from you ham handed attempts to remove the prior bearings. There is a good reason most people have the machine shop install the cam bearings! It is worth the ~$50 or so they charge.
And as LR said, be sure the oil holes line up.
Rich
Old Oct 13, 2007 | 06:50 PM
  #43
Advice taken!
What did you mean by this?
Old Oct 13, 2007 | 08:51 PM
  #44
rskrause's Avatar
Moderator
Originally Posted by marshall93z
Advice taken!
Jk Just be careful removing the old bearings to avoid problems!
Rich
Old Oct 14, 2007 | 02:28 AM
  #45
Problems?
