cam bearing question
Old Apr 22, 2006 | 08:17 PM
JustAnotherGuy's Avatar
Question cam bearing question
finally got my engine apart for a H/C swap
the engine has around 130,000 miles on it.
Inside of the engine looks in excelent condition, found very lil if any signs of wear.
but the front cam bearing seems to have a slight ridge on the back of it even though I can't seem to feel it with my fingernail. the cam does not appear to have any signs of wear.
should this be ok? or should i replace the front bearing?
im leaning towards thinking it will be just fine. since i cant really seem to find any threads talking about spun cam bearings.
Thanks for any help
-Matt
Old Apr 22, 2006 | 11:10 PM
Re: cam bearing question
IMO, with that many miles, all cam bearing should be replaced.
Old Apr 23, 2006 | 06:50 AM
rskrause's Avatar
Moderator
It would be foolish to have a motor with that many miles apart and not replace the cam bearings.
Rich
Old Apr 23, 2006 | 12:31 PM
zlightning's Avatar
How do you replace cam bearings?
Old Apr 23, 2006 | 06:56 PM
camaroKid223's Avatar
replace all bearings, you'll thank yourself later
Old Apr 23, 2006 | 10:11 PM
...with the correct tools or let a shop do it.
Old Apr 23, 2006 | 10:53 PM
chevelles101's Avatar
so what are the correct tools for replacing the cam bearings?
Old Apr 23, 2006 | 11:08 PM
sssalah's Avatar
I would let a shop change them, there's a certain procedure for doing these. I didn't know you can get a single bearing, always thought that they came in a set of five.
Old Apr 24, 2006 | 04:05 AM
rskrause's Avatar
Moderator
You can buy them individually, but in this case he should replace all five. It is not too difficult but needs a special tool like the one on this page. Note: each bearing has to go in the proper location. They are numbered.
Rich
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
chuyz28
Nov 25, 2014 11:14 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
