cam assembly lube
Old Aug 10, 2003 | 02:43 PM
94formulabz's Avatar
cam assembly lube
Where was it supposed to be included. In the actual cam box? I think i got ripped I don't want to wait till monday for this, the old one is out now. It's the CMotorsports 218 kit.
Old Aug 10, 2003 | 02:47 PM
AsianSensation's Avatar
No cam assembly lube in my hotcam kit either. So I went to NAPA and bought some. $6, more than enough.
Assembly Lube
Old Aug 10, 2003 | 03:00 PM
thewinner's Avatar
just use oil
Old Aug 10, 2003 | 03:09 PM
Mikey97Z's Avatar
Assembly lube goes on parts that rub together. It's needed on flat tappet lifters but we have rollers so CompCams recommends oil on the cam.
Old Aug 10, 2003 | 03:47 PM
Comp Cams and Crane Cams recommend oil just on the bearing journals and assembly lube on the lobes and oil pump drive gear. Most people just put assembly lube on every thing so it doesn't drip off. But to each their own.
Old Aug 10, 2003 | 03:57 PM
tryme96Z's Avatar
take the time and get assembly lube.
Old Aug 10, 2003 | 04:15 PM
thewinner's Avatar
you guys act like it is a big deal to use oil. oil is fine, its not gonna hurt anything. Roller cams arent gonna wear much. hell i dont even remember if even put any lube on my cam into my new motor. Maybe al ight coating of oil, but thats it.
Old Aug 10, 2003 | 06:34 PM
My bro drove in and got some Lunati lube for me. I really thought it was supposed to be included with every comp cam though. Oh well.
Old Aug 10, 2003 | 07:30 PM
12SCNDZ's Avatar
What's said above is true. Assembly lube is only needed when parts need to be broken in. A roller cam and lifters don't need to be. I used good ol' Pennzoil 10 W 30.
Frank
Old Aug 10, 2003 | 07:40 PM
96speed's Avatar
Assembly Lube
That is what I used .
Ryan
Old Aug 10, 2003 | 11:47 PM
Dave Feerst's Avatar
oil is fine for roller cams. thats what i used.
Old Aug 10, 2003 | 11:57 PM
Everyone grab their beer of choice and have one with me, i'm done for the night.
I worked 1-8 sat and 10am-1230am today. The cam is in, vavle springs changed, CSI in the housing. I still need to put the intake back on, adjust the rockers, wire the csi, then fire er UP! Might take off of work tuesday to try to wrap it up.
Old Aug 11, 2003 | 09:45 PM
arnie's Avatar
What method are you gonna use to break in the cam?
Old Aug 11, 2003 | 09:59 PM
gb95zconv's Avatar
I would use the lube or STP oil treatment....you need something that will adhere better than regular motor oil IMO.
Old Aug 11, 2003 | 10:15 PM
run 20 min while i bleed the rad ect.
change the dinosaur oil
two tanks of gas
back to mobil 1, give her hell and hope i wasn't too dirty.
-brent
