Cam advance question with Cloyes double roller timing chain
Old Feb 27, 2019 | 12:10 PM
Red_94Formula's Avatar
So every after market cam I see is 4 degrees advanced timing. I am pretty sure I saw that even the stock cam is 4 degrees advanced. I think the theory here is that the timing chain stretches some and actual timing is no so advanced as 4 degrees. I am looking to order a custom cam. With a custom cam I can order my lobe separation of 110 with an intake center line of 106. Which is 4 degrees advanced. My question is does the 4 degree advance still hold true with a double roller? I am thinking a double roller has less stretch then the stock type timing chain but I may be wrong here. Thanks in advance!
Old Apr 2, 2019 | 08:41 AM
Re: Cam advance question with Cloyes double roller timing chain
To answer my own question the double roller timing chain will still stretch from what I read in forums and this you tube vid
. It took that guy 20k miles to stretch 4 degrees on his Cloyes double roller on a BBC. I am sure there are many factors that can effect the timing stretch such as valve train mass, rpm range, and valve spring pressure rates. When I order my custom cam it will be 4 degrees advanced.
84firebird
Advanced Tech
Mar 4, 2006 07:10 AM
84firebird
Classic Engine Tech
Mar 2, 2006 09:05 PM
97formulakid
Jul 16, 2005 01:48 PM
Z28sky5
Jun 29, 2005 10:37 PM
firebird_fury
Mar 30, 2004 06:31 PM
