Timing chain q
Old Mar 2, 2006 | 09:05 PM
84firebird's Avatar
Timing chain q
Hey, I've got a double roller timing chain from melling i believe got just a few thousand miles on it. At present, I just swapped my cam, and when i bolted the timing chain back up, there's some slack in it, fresh rebuild going on a couple thousand miles (maybe 4000 at most) and i wanted more power so i put in a newer lunati cam grind....
It's a 350 bored .030 compression at 9.34-1 cranking is 165 psi (yea the cam has a pretty late closing intake valve), all the parts checked out fine on the topside...however...
If i remember correctly, that chain is supposed to be tight, and it's currently got a good couple degrees of play.
is it just a case of pos defective part? that's what i'm banking on, but then who do i go through for a new double roller timing chain?
thanks for the input
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
