Cam and 7/16th RR installed. Timing chain question.
Old Feb 9, 2004 | 06:46 AM
DR.ZED's Avatar
Finished my Comp Cams 221/227, .542/.560 112 installation this weekend. Included were guideplates, 7/16th studs (surprised at how much larger the stud is compared to the stock 3/8ths).
I installed my timing chain, and did about 5 revolutions of the motor, and the timing dots still lined up (with the full valvetrain on).
The stock timing chain (new) is really loose. I suspect this is normal, but I'm surprised really. Does everybody else have this same experience?
I've never seen a timing chain that is so loose.
Thoughts?
Old Feb 9, 2004 | 06:54 AM
ImportsRsloths's Avatar
My thoughts are to hop on over to Thunder Racing, and buy the LT4 Extreme Timing Chain set..... It does have a juicy price tag though!!
Old Feb 9, 2004 | 06:55 AM
Grease's Avatar
Did you replace the gears as well or just the timing chain? Gears wear out too.
Old Feb 9, 2004 | 06:59 AM
DR.ZED's Avatar
The gears look good. If the gears were worn, wouldn't they wear at the top where it wouldn't affect the slack?
Old Feb 9, 2004 | 07:26 AM
truedualws6's Avatar
I picked up the extreme duty timing set for my
cam swap. Now is the time to make the switch
if you are so inclined. It's a lot of work to pull it
apart again.
Old Feb 9, 2004 | 07:39 AM
The gears and chain wear as a set. Though you might not be able to see it well, the wear is there. Even a brand new stock set seems to have a bit more slack in it than desired, so just putting a chain on old gears would probably be even more.
Old Feb 9, 2004 | 08:28 AM
Don 97 SS's Avatar
Always replace the gears and chain as a set is my advice.
The oem LT1 chain is a joke. I installed a the GMPP LT1/LT4 HD timing set that last time my engine was apart. I would highly recommend it over the wimpy LT1 chain set.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
