Cam
Old Oct 9, 2008 | 06:33 PM
z28camaro1090's Avatar
Cam
How can i tell if i have a cam installed in my motor or any other internals.. because i bought the car after motor and tranny was rebuilt.. and i pull real hard on 93's that have similar work as mine does.. also i ran with a goat in the 1/4 and lost by about 2 feet.. i know that i must have more done to my car
Old Oct 9, 2008 | 08:17 PM
ricehammer's Avatar
Aside from pulling the cam and looking for stampings, you could remove a valve cover and use one of these http://store.summitracing.com/partde...5&autoview=sku, less the degree wheel (for a rough idea), to measure max lift on the cam. It's kind of a PITA since you have to rotate the crank slowly and watch the depth gauge. Then compare to stock - Camshaft Specs (12551705): 205/207 duration @ 50*, .447/.459″ lift w/1.5:1 rockers, 117 Lobe Separation Angle. Stock cam lobe height is 0.298/0.306.
Old Oct 9, 2008 | 08:26 PM
thanks yeah i think im gonna buy a cam and put it in .. and if there was one already i will just sell it.. im not really that concerned seeing if there was any tricks that i didnt know.. but i didnt think soo
Old Oct 10, 2008 | 03:48 AM
Counted Out's Avatar
Most likely the old owner would have told you something like that. 93's are known for Factory Freaks, but who knows.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
