cam?
Old May 8, 2008 | 11:39 PM
SmokinZ28lt1's Avatar
cam?
Well i'm buying a cam for my 1994 z28 but there are so many i dont know what would work well with my car its stock exept for cold air intake and i hollowed the cat out. but i would like it to pull better top end i was thinking about getting this one but i didnt know if it would be to much for the stock heads or make it idle really rough
DURATION LIFT (1.5) LIFT (1.6) LOBE
COMP CCA-224-230-12 224 230 . 503 .510 .537 .544 112 1900-5600 rpm
but it would be a big help if you could help me out
Old May 8, 2008 | 11:47 PM
PortMasters's Avatar
You will need a good set of headers to take advantage of the cam, and a tune for sure. That cam will work well with stock heads though if your heart is set on it. The idle is very nice in 6 speeds and still pretty decent in auto cars too.
Old May 9, 2008 | 01:16 PM
K well is hypertech a good tuner or what are some good ones?
Old May 9, 2008 | 01:25 PM
jtarp's Avatar
dont go with the hypertech. try a mailorder tune like pcmforless.com
Old May 9, 2008 | 02:39 PM
stealthformula's Avatar
I ran that cam on stock heads and loved it. You really need to get some Headers tho, the idle is pretty choppy and sounds great, will need a good mail order tune or a dyno tune to drive nice. If your an automatic you will need a stall first, I drove it without a stall for a while and the car drove like crap. If your a stick you are fine. Not sure where you are willing to rev the motor but it will want to be shifted upwards of 6300-6400 for maximum performance.
Old May 9, 2008 | 03:26 PM
TitoPR221's Avatar
The stock valve springs may have a difficult time dealing with lifts above 0.500" or rpms above 5,500. You may want to consider upgrading valve springs and take the opportunity to install 1.6 RRs.
Old May 9, 2008 | 05:22 PM
2000GTP's Avatar
True, I wouldn't trust any aftermarket cam with stock springs.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
