CAI and catback or headers
Old Jul 26, 2003 | 02:20 AM
Cmr0z28's Avatar
i already have a magnaflow muffler with stock piping and an electric cutout before the rear axle... and a k&n filter. i have about enough money for a hooker catback and moroso CAI......so i was wondering if i should get those or save more and get jet hot coated long tubes?
OR
3.73s
Old Jul 26, 2003 | 02:37 AM
94 CAMRO Z28's Avatar
Your going to want all the mods sooner or later. So I guess its just the order at which you do them. I guess seeing that your on a budget, and you have a cutout already, that probably opens up the exhaust enough considering your on stock cam/heads. I would save for the headers and then either pick up a used CAI or make one yourself out of PVC. Good luck..
Aaron
Old Jul 26, 2003 | 03:25 AM
Red96Lt1's Avatar
I'm not a fan of the homemade CAI. There is actually engineering that goes into them. Get a K&N CAI, or some other reputable brand.
Old Jul 26, 2003 | 04:23 AM
scoobysnax83's Avatar
engineering smengineering.... If you have a round tube that is sucking clean hi-flow filtered air from a cool (not engine bay)source not pulling water... Then you have a great CAI. Nothing much more to it. If you can build it yourself (very easy) you can save a lot of money and get the same results.
Old Jul 26, 2003 | 11:55 AM
Red96Lt1's Avatar
Well if that's the case, why don't they just sell you a piece of PVC pipe for a CAI?
It's not only cold air, it reduces turbulence as well. If you're making 90 bends with PVC, you're going to make some turbulence.
Old Jul 26, 2003 | 12:00 PM
AsianSensation's Avatar
There is engineering that goes into CAI. CAI has a bottle neck that acts as a venturi to gets the incoming charge velocity up.
Old Jul 26, 2003 | 12:14 PM
Antz97ZNJ's Avatar
cai and headers definately
Old Jul 26, 2003 | 06:26 PM
Cmr0z28's Avatar
thanks
Old Jul 26, 2003 | 06:44 PM
Brettinator's Avatar
definitely CAI & Headers dude
Koby
Jun 28, 2015 04:46 PM
Russ95Z28
Apr 23, 2015 01:55 PM
thenewkid
Apr 12, 2015 07:42 PM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
