C.A.T.S Tunercat Questions <-- Users enter please!
Old Apr 6, 2005 | 09:39 AM
wb3s94z28's Avatar
So i want to order Tunercat instead of LT1 edit. What do i need to order to start tunning?
RT Tunner (which should come with a deffinition file right?)
Any Definition files?
CalData?
TDFEditor?
What did you guys start out with? This is my current experiment and i'm also ordering an LM-1 wideband o2 device.
Old Apr 6, 2005 | 09:46 AM
madwolf's Avatar
Re: C.A.T.S Tunercat Questions <-- Users enter please!
You need the Tuner program ($69.95) and the EE/EEB definition file ($19.95)
You will also need a cable if you haven't already purchased one. The website is www.akmcables.com
Old Apr 6, 2005 | 11:20 AM
wb3s94z28's Avatar
Do you use a wideband when you tune? I'm gettting one, but the tuner and cable will be here alot faster than the LM-1, do you think i could still pull off a good tune without the wideband?
Also the EE/EEb definition file...is that the same as the $EE definition file?
Old Apr 6, 2005 | 11:39 AM
madwolf's Avatar
I don't like the handheld units like LM-1. They are garbage in my opinion, even though I might get flamed for this.
The wideband I use are the ones which come as a package with a dyno purchase. (so basically I dyno tune on the dyno)
You can work on your part throttle until your handheld unit arrives. Yes, the EE is the same as EE/EEB, but EE is what you'll want to use.
Old Apr 6, 2005 | 04:15 PM
WS Sick's Avatar
Also a way to log data is handy as well, I use Datamaster. But others use other programs.
The first thing to do is take your time and read read read on the net and ask questions. The Thirdgen site has a good section for DIY tuning although alot of the tables etc are named different for their stuff. But the basics are there and well described. I havent got a wideband yet but plan on one. I have done most of my tuning by driving in different situations (wot, and around town) it's taken probably 20 flashes but I'm learning and getting there. Do changes in small increments.
Old Apr 6, 2005 | 08:08 PM
wb3s94z28's Avatar
I have been researching and reading everything thing possible. I'm checking out TTS datamaster.
Old Apr 6, 2005 | 09:13 PM
1badasZ's Avatar
what about the wide band commander? is it a pretty good one Ion...if you have any experience with it that is. i was thinking about looking into buying some sort of wideband setup eventually
Moshbmx1
Feb 17, 2015 10:51 AM
maybe2fast
Feb 5, 2015 05:14 AM
Jlo
Feb 3, 2015 09:41 PM
rjc1629
Jan 27, 2015 10:46 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
