A/C and Smog delete
Old May 18, 2010 | 11:43 PM
mike 1972's Avatar
A/C and Smog delete
Does anyone know where I can get a A/C and smog delete brackets at? Also a EGR delete plate? And finally what all is involed and can I get rid of when doing this?
Old May 19, 2010 | 05:40 AM
The A/C delete part is a "1LE" bracket/pulley from GM. Shoebox has the part # on his website. Not sure if GM still makes it. There are rip-off copies available on ebay, but most of them are Chinese junk.
There is no "smog" delete bracket. The AIR pump is electric, and can simply be unplugged and unbolted, along with all the plumbing. Plug the air supply connection from the air intake ducting, and the AIR check valve connections on the exhaust manifolds. The EGR delete plates are avialable from:
http://www.sjmmanufacturing.com/
Old May 19, 2010 | 09:41 AM
byrons1502's Avatar
Why are you deleting this stuff
Old May 19, 2010 | 10:06 AM
Procharged94Lt1's Avatar
I did it on mine for a cleaner engine bay- not so much for the rumored power addition.
magman
Apr 15, 2016 03:08 AM
WPHIG2
Aug 27, 2015 06:37 AM
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
colts0455
Jul 8, 2015 12:21 AM
