A/c Remove help
Old Aug 20, 2005 | 08:41 PM
mach1engines's Avatar
A/c Remove help
I am removing the AC compressor, but I am having a b**** of a time getting the bolts in the back off. Read all the articles on her, but still having trouble. someone PLEASE help me! Thanks
Old Aug 20, 2005 | 09:23 PM
krispy's Avatar
Re: A/c Remove help
its a ****ing bitch and a half, I had to use a small rachet and it was hard as **** to loosen, there is only one bolt holding on the inlet/outlet tube (which is the hard one) and a couple other easier ones, just do whatever you can to get a rachet on
make sure you take out the fan assembly after you get the bolts off or you wont be able to take it out (at least I had that problem)
Aug 5, 2015 08:35 AM
MikeWhitener
Aug 2, 2015 06:17 PM
4586
Jul 31, 2015 06:03 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Jul 17, 2015 02:47 PM
