A/C Question
From: San Juan Puerto Rico, Look it up it's in the Caribean
Hi, guys
I have a 95 Z28 Camaro and my a/c its not working, I think that is the compressor but I am no sure. My neighbor has a totaled 95 camaro 3.4V6 and I want to know if can use the complete setup of the v6camaro. V8 and v6 have the same A/C setup ???
I will appreciate your help thanks you !!!!!!!!
Re: A/C Question
No, they won't transfer. Check to see if you have 12V at the compressor. If not, then you have either a relay, fuse, or pressure switch failure. Work backwards and you will find the problem.
jasonduaine
Mar 7, 2015 09:44 AM
