A/C Q? What psi should high and low ports be?
Old Sep 12, 2004 | 11:36 PM
Sacramentoz28's Avatar
Exactly what the title says. I'm getting 130psi on the low and 125-130 on the high side. That seems way too low on the high side. A/c runs like crapola...warm!
-Omar
ps I had no clue on where to post this
Old Sep 13, 2004 | 08:05 AM
Re: A/C Q? What psi should high and low ports be?
It's a general tech question.
A/c performance chart
Old Sep 13, 2004 | 10:17 AM
Those numbers seem really low. Is that for r-12?
Thanks for the info tho.
Old Sep 13, 2004 | 12:14 PM
HBHRacing's Avatar
your pressures are equalized due to the compressor not runing.
also. your overcharged
Old Sep 13, 2004 | 02:19 PM
The clutch engages, so I know the compressor is running. Although the clutch might not be grabbing like it should resulting in a lower high side pressure.
How do you conclude that im overcharged? Is that table that shoebox posted correct?
Old Sep 13, 2004 | 03:45 PM
Dave C. '97 Z28's Avatar
I agree that if the pressure is near the same on both sides, the compressor is not compressing.
With the compressor on, and with a good charge you should see ~25-50psi on the low side, and on the high side it should be up towards 200psi.
-Dave C. '97 Z28
Old Sep 13, 2004 | 03:49 PM
HBHRacing's Avatar
you should never see more then about 100-110 PSI on the low side at it's max. And it will be it;s highest when the AC is off. with it being over that you are over charged. the fact that you have high low side pressures and low high side pressres and the compressor is running means that the internals of the compressor have come apart. that means no sucktion to lower the low side and no pressure to raise the high side. My guess would be the overcharging blew the comprssor.
Old Sep 14, 2004 | 07:25 PM
popsz28's Avatar
woudnt a high pressure on the low side and a low pressure on the high side also indicate a blockage in the system?
Old Sep 15, 2004 | 12:14 AM
awesome. Thanks for the help guys. I just needed more convincing to myself to tear out the ac compressor. I think I'll wait until it gets a little cooler outside until I tackle that problem.
Hopefully its not the whole compressor. I'm hoping its just a clogged orafice tube.
-Omar
HectorM52
Jun 23, 2016 08:42 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jan 23, 2015 01:13 PM
My94RedZ28A4
Aug 11, 2002 10:04 PM
