A/C makes my car overheat
Old Aug 25, 2008 | 04:55 PM
sooperdood3's Avatar
96 firebird formula. just got my A/c system recharged, now i cannot use it without the temp guage running into the red. i bled the cooling system. what could the problem be?
Old Aug 25, 2008 | 05:04 PM
Prorac1's Avatar
Make sure when you turn on the ac the fans come on, thats the first place id check. Eric L
Old Aug 25, 2008 | 10:16 PM
they do. sometimes my compressor doesn't kick on initially tho
Old Aug 25, 2008 | 10:43 PM
rednblack94z28's Avatar
interesting, my car actually over heats if i DONT use the A/C lol.
Old Aug 26, 2008 | 11:37 AM
Z28SORR's Avatar
It should actually run cooler with the AC on. As both fans are supposed to come on with the AC. Check the wire connection to and from the AC.
Old Aug 26, 2008 | 11:45 AM
user 647483's Avatar
If the fans are working correctly (and thus the relay and wiring are good)
then you might want to check your Coolant/Water mix. Should be close to 50/50
If you run an EWP, check it's wiring as well.
Old Aug 27, 2008 | 12:08 AM
red67camaro's Avatar
Also take a look at the radiator and condenser fins and be sure they haven't collected bugs, dirt, and other road debris. Wash them out as necessary.
Sometimes dirt and such can make it through the condenser and collect in front of the radiator where it can't easily be seen.
Old Aug 27, 2008 | 06:59 PM
applecorn37's Avatar
Not always. Even though the AC fan is on, its pulling all the heat from the AC system through the engine radiator. The other fan only comes on when the coolant temp reaches 210 or something (for my 95 anyways).
Old Sep 1, 2008 | 09:12 PM
fans come on, cooland is around 50/50, water pump is stock and is correctly pumping water, condenser fins and radiator fins look clean; hosed them off anyway...
my car generally runs hot anyway... is it possible i have mineral buildup in my radiator? how do i check for that? i have run some radiator flush thru there once.
Old Sep 13, 2008 | 09:57 AM
i...i...i think i found my problem... after my car overtemp'd and busted my waterpump... took the radiator cover off to remove the fans and a FRIGGIN EMPTY 30PK OF BUD LIGHT was between the radiator and the condenser! why would someone do that???
Old Sep 13, 2008 | 10:36 AM
stvski80085's Avatar
I'm assuming you mean the card board was between it. If thats the case sometimes people do that kinda stuff in the winter so the car runs warm and they get better heat inside the car. Then they forget to take it out. you see it on the trucks all the time. They block part of the air flow.
Old Sep 13, 2008 | 02:20 PM
SC/TA's Avatar
I have the same problem, but no bud light pack for me. My temp will start climbing within seconds of turning on the a/c. Any other ideas?
Old Sep 13, 2008 | 11:48 PM
but isn't it gonna run warm anyway since the thermostat won't open til the car gets warm?
i'm still mad tho cos this just cost me a headgasket and a waterpump
CaRParts102
Dec 6, 2014 08:45 AM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
pologreen97z
Dec 2, 2014 10:42 AM
USAirman93
Nov 24, 2014 03:37 PM
