A/C makes my car overheat
Also take a look at the radiator and condenser fins and be sure they haven't collected bugs, dirt, and other road debris. Wash them out as necessary.
Sometimes dirt and such can make it through the condenser and collect in front of the radiator where it can't easily be seen.
Not always. Even though the AC fan is on, its pulling all the heat from the AC system through the engine radiator. The other fan only comes on when the coolant temp reaches 210 or something (for my 95 anyways).
fans come on, cooland is around 50/50, water pump is stock and is correctly pumping water, condenser fins and radiator fins look clean; hosed them off anyway...
my car generally runs hot anyway... is it possible i have mineral buildup in my radiator? how do i check for that? i have run some radiator flush thru there once.
i...i...i think i found my problem... after my car overtemp'd and busted my waterpump... took the radiator cover off to remove the fans and a FRIGGIN EMPTY 30PK OF BUD LIGHT was between the radiator and the condenser! why would someone do that???
I'm assuming you mean the card board was between it. If thats the case sometimes people do that kinda stuff in the winter so the car runs warm and they get better heat inside the car. Then they forget to take it out. you see it on the trucks all the time. They block part of the air flow.
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
