A/C delete Vac lines question
Old May 29, 2003 | 05:59 PM
Ponykillr's Avatar
What to do with the vacume lines after completly removing the A/C? Should I just block them off? I am leaving in the Fan unit on so I will still be using one line to the HVAC controlls but the rest I will not need. Any sugestions?
Old May 30, 2003 | 09:15 AM
What vacuum lines? There is one from the back passenger side of the intake manifold for operating the flapper doors on the AC/heater system, and if you still have the fan, you might want to leave the vacuum system intact so you can still direct the air flow to the defroster. You could remove the small vacuum canister mounted to the frame rail inside the passenger side front fender.
What other vacuum lines are you concerned about?
HectorM52
Jul 30, 2017 11:46 AM
alphaauto
Feb 5, 2015 05:25 PM
Jason Short
Jan 19, 2015 06:34 PM
cmdeshon
Dec 27, 2014 10:06 AM
pologreen97z
Dec 2, 2014 10:42 AM
