A/C compressor not coming on?
Old Mar 17, 2004 | 07:52 PM
AW/whiteZ-28's Avatar
I checked the relay its fine. I checked the compressor it isn't stuck. I used a jumper wire and it came on like that, so I have narrowed it down to the power wire that activates the relay. But, is there something else in line to the relay that could be messed up or am I gonna have to replace the entire wire?
TIA
Archie
Old Mar 17, 2004 | 08:52 PM
HBHRacing's Avatar
first you need to make sure that you ahve enough freon to let the system come on. if you do.. I would check the pressure switch on the AC line. should be a 3 wire switch. unplug it and jump power from the red wire to the grey aire at the connector and see if it comes on then
Old Mar 17, 2004 | 11:19 PM
Ok I'll try that
Old Mar 17, 2004 | 11:21 PM
Also, if you have had a DTC for pressure problems, the PCM will lock out operation of the compressor. You have to reset the PCM to clear it.
Old Mar 18, 2004 | 10:06 PM
Yea that's what I'm thinking it's gonna be I'll try that tomorrow
just got back from work and I'm soooo tired....
HectorM52
Jun 23, 2016 08:42 PM
alphaauto
Feb 5, 2015 05:25 PM
alphaauto
Jan 23, 2015 07:42 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
