a/c clutch
Old Jun 25, 2003 | 12:46 AM
godofdragons's Avatar
a/c clutch
my a/c clutch wont kick on when i turn it on so i dont even know if theres freon in it, any ideas?
Old Jun 25, 2003 | 01:27 AM
Z28Nut's Avatar
Mine did that two years ago and it turned out to be the ac controller in the dash wasn't triggering the ac clutch relay. In the fuse/relay block under the hood you can pull the ac clutch relay and jumper the terminals to see if the ac clutch kicks in and if the system blows cold air. I bought a guage for adding 134a and checked to see if the system had refridgerant in it before trying it. I think the relay has a diagram on it as to which terminals are to the clutch. Crimp a couple of spade connectors onto a short length of wire and jumper those two terminals. You'll hear the clutch kick in if its working and that'll point to the controller. The ac system also has an upper and lower pressure limit switches that prevent it from running if the system pressure is too high or low. The pressure guage will tell you if that's the problem.
magman
Apr 15, 2016 03:08 AM
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
