Buying a Spec Stage 3, what else do I need?
Old Apr 9, 2003 | 09:51 AM
tryme96Z's Avatar
I am getting ready to order a Spec Stage 3 Carbon disk clutch. What all comes with the clutch and what else do I need? I heard I need an input bearing?
Old Apr 9, 2003 | 10:59 AM
IRABuss's Avatar
you might want to replace the pilot bushing, but other than that you should be fine. If you are not getting a new fly wheel, go get your old one turned. I had 15 thousands turned off mine and just put it on with no spacer. This makes the clutch grab a little closer to the top. if the hydraulic system is old, might want to get another one of those. you can always replace that down the road if it is not working right.
Old Apr 9, 2003 | 11:32 AM
tryme96Z's Avatar
What is the pilot bushing? I think that is what the input bearing is? Who sells good ones? How much should turning a flywheel cost?
Old Apr 9, 2003 | 11:53 AM
IRABuss's Avatar
the pilot bushing goes in the back of the crank...It is what the input shaft rides on. I would get it from the dealer.
the flywheel will cost you about 20 or 30 bucks to have it re-surfaced. Tell them to take as little as possible off....
SpeedJunkee
Apr 23, 2015 01:32 PM
R@mpage
Apr 20, 2015 10:02 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Ws6Envy
Mar 3, 2015 04:31 PM
