Buying an LT1 intake, any diff in castings?
Old Feb 24, 2008 | 01:15 PM
ssbowtie1's Avatar
I have a 96 ws6. I need to fix the intake oil leak. I was planning on buying an lt1 intake ($40 local) and having it powdercoated, then installing that intake on my car to minimize downtime. Are there any real differences between casting numbers from 94-94?
Old Feb 24, 2008 | 01:20 PM
n2ceptor's Avatar
93- Different fuel rail
94-96 same fuel rail and 96 LT4 has taller ports
I dont recall any other differences....
Old Feb 24, 2008 | 03:04 PM
96capricemgr's Avatar
As mentioned the early castings lack the fuel rail crossover, avoid those and you will be fine.
The LT4 intake does NOT I repeat does NOT have taller ports. The heads do but the intake internally is the same as some of the LT1 intakes, just has more material above the port wehich will interfere with the LT1 head valvecover rail.
Among the probably 2-3 castings that are LT1 and have the fuel rail crossover the differences are not anything to get worked up over, they will all work for you.
Old Feb 24, 2008 | 03:22 PM
n2ceptor's Avatar
Learn something new every day.....
Old Feb 24, 2008 | 03:32 PM
http://i85.photobucket.com/albums/k5...1/DCP_1456.jpg
GIZMO from over on LS1tech was good enough to share this with the community.
HectorM52
Jun 23, 2016 08:42 PM
*Emilia*
May 13, 2015 09:05 AM
LT14LIFE
Feb 9, 2015 09:35 PM
ddr698
Jan 9, 2015 10:05 AM
