busted sensor what is it? (PIC)
Old Feb 14, 2004 | 09:48 PM
tim95z28's Avatar
Guys, during my cam, header install I have busted a sensor, on the front of the driver side head. Can someone tell me what it is and if I can get it at a local parts store? Here is a pic.
thanks!
Old Feb 14, 2004 | 09:50 PM
95BlackTA's Avatar
tells you the temp of the engine
http://shbox.com/1/temp_sensor2.jpg
Pretty good, that was my first guess and I had no clue...just picked that off his website
Old Feb 14, 2004 | 09:54 PM
tim95z28's Avatar
good site thanks! Used to working on older cars, I just unplug this junk and plug it back up, not knowing what it is!
Old Feb 14, 2004 | 10:24 PM
Stoopalini's Avatar
There are two temp sensors on your motor. The one you broke is the one that feeds the dash gauge. The other temp sensor is located in the waterpump housing. It feeds the PCM the coolant temp.
You should be able to get a replacement at any local autoparts store. Just make sure they give you the correct temp sensor; since there are two of them.
Ask for the one that installs in the head.
Thomas.
Fastbird93
Apr 9, 2016 07:01 PM
LT14LIFE
Feb 9, 2015 09:35 PM
rjc1629
Jan 27, 2015 10:46 AM
Queens94z28
Dec 20, 2014 09:11 PM
