burning out a lot of starters!!!!
Old Jan 26, 2004 | 11:38 PM
billygoat's Avatar
My car starts good cold but after driving around town for 20 -30 mins the starter will not turn over engine like its hot i have a 6 speed so it push starts no problem, i have headers is the heat from those doing saomthing screwy to starter this is 2nd in 4 months and does any one use those mini starters? are they good and are they worth the money for the space they save when installing them?
Old Jan 26, 2004 | 11:41 PM
c0rey's Avatar
My starter does the same thing since headers
Old Jan 27, 2004 | 01:57 AM
Fatdog's Avatar
Cool
I'm not sure,but previous posts have suggested a heat shield for the starter.I think when the starter gets too hot,it has a safety device inside that shuts itself down.Anybody else?
Old Jan 27, 2004 | 02:51 AM
philcam01's Avatar
I have long tube headers and there real close to my starter with no hot start problem at all . It sounds like to me you need a A/C delco starter not some cheap Autozone or Pep Boys rebuilt crap.
Old Jan 27, 2004 | 02:59 AM
c0rey's Avatar
I have a ac delco starter, But my headers arent coated maybe thats the problem my starter gets hot and clicks, then after 3-4 times it'll fire right up.
Old Jan 27, 2004 | 05:22 AM
Don 97 SS's Avatar
Heat increases electrical resistance. So if your electrical connections are not real good you may be able to start when the engine is cold but the connections get increased resistance when warm and create problems. I'd first check for good clean and tight connections to the solenoid. That won't cost you any money. If that doesn't work consider a heat shield around the solenoid. Furd unlike GM decided a long time ago to put their starter solenoid away from the high heat area around the starter motor.
You may also have bad starters as mentioned above. If you are buying remans some are good and some are junk. Get the GMPP lightweight starter. I bought a GMPP version for my BBC engine and I love it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
TitoPR221
May 26, 2015 12:20 AM
markzzzz
May 8, 2015 09:21 AM
blac94Z
Apr 22, 2015 04:53 PM
