Building a V6 into a 383...
I plan on buying a V6 Camaro soon and gutting it and rebuilding the car with a 383 stroker. I have a few drivetrain questions. First off does anyone know a good engine shop that has reliable forged 383's? I plan on putting a supercharger on it eventually. Next, will a tremmec T-56 withstand a 383 since they produce about 450hp and a supercharger on top of that? Lastly, would a 12 bolt stock rear from a newer z28 or SS be able to take the power?
Any help is appreciated. Im going to take my time building this car and not spare a cent.
Re: Building a V6 into a 383...
Good place that builds reliable 383's? Victory Racing Engines. www.victoryracingengines.com
NOTE from Moderator: Unpaid advertising is not permitted. If you want to advertise, you need to be a "supporting advertiser"..... instructions linked at the top of all pages.
People have reliably taken the T56 to about 800HP, and run into the 9's with it. Some upgrades may be needed to reach those levels.
The "newer Z28 or SS" will not have a 12-bolt rear. All 4th Gens got the same weak 10-bolts. Any aftermarket 12-bolt can be built to handle 800-1000HP.
Golen, Victory, or even Combination builds a pretty good short block.
If I were to attempt the swap you're talking about, I would look into an iron block 408 LS1 from one of the vendors.
CARiD
Sep 30, 2015 05:44 AM
