Building a Stroker
Old Jun 29, 2003 | 11:11 AM
DavidsZ's Avatar
Building a Stroker
I am in the process of building a 383 stroker. I have a 94 Lt1 and i was wondering what the best complete stroker package to use was. Also what is a good cam to use with the 383 stroker. Is the LT4 hot cam kit compatible. Thanks
Old Jun 29, 2003 | 11:35 AM
FacelessZ's Avatar
LT4 HOT is WAYYY too mild for as stroker. You'd want to weigh your choices...decide how much you want to spend on a stroker kit...and look more into what cam you'd want...Comp Cam offers some good custom grinds...many have gone with the CC306 but thats more with a mild stroke....
Do some research and see what you come up with. Try www.strokerkits.com
Good luck!
Old Jun 29, 2003 | 11:40 AM
96z's Avatar
96z
Hey youve made perfect timing. Bauer Racing has a Group Purchase going on right now with every stroker kit imaginable to suit your need.
Bret from Bauer Racing built mine and It made the numbers in my sig.
Check it out....
http://web.camaross.com/forums/showt...hreadid=137241
Old Jun 29, 2003 | 11:47 AM
DavidsZ's Avatar
thanks
thanks for the help. also what all must be reprogrammed in the computer for everything to work together. thanks
Old Jun 29, 2003 | 11:49 AM
FacelessZ's Avatar
You can choose to go with a mail-in tune through pcmforless.com. Just let them know everything that you've had done and they'll hook you up for a decent price.
www.pcmforless.com
Old Jun 29, 2003 | 11:51 AM
FacelessZ's Avatar
96Z
Could you tell me approximately how much gas mileage I'd be losing if I had decided to, say, go with the stroker set-up you've used? How 'streetable' is it?
Any info would be a great help!
Novo
Jun 14, 2016 02:58 AM
CARiD
Sep 30, 2015 05:44 AM
pepon214tx
Sep 20, 2015 04:48 PM
95craz28
11
Sep 12, 2015 07:47 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
