Building an LT1, can I use a Vortec 350 shortblock?
Old Oct 17, 2007 | 12:19 PM
  #16
There's a member here who built a 427ci LT1 (4.00 stroke x 4.120 bore) using sleeves. The LT1 block has been pushed by many in excess of 1,000 flywheel HP. There's a member with a twin-turbo who claims he is now looking at 1300-1400 rw HP.
If it isn't built with an LT1 block, it isn't an LT1, IMHO.
Old Oct 17, 2007 | 02:13 PM
  #17
bufmatmuslepants's Avatar
spring 2009 i get my ME degree...this sounds like a project to me
Old Oct 17, 2007 | 02:22 PM
  #18
The Engineer's Avatar
Which, developing an LTx tall-block, or reworking an existing LT block w/ 4" stroke and 4.1" bore???
I have a 3.875" stroke LT engine (396 CID) with notches in the block near the pan mounting surface, rod cap-bolts clearanced and small base-circle cam.
WD
Old Oct 17, 2007 | 02:28 PM
  #19
blue89rs's Avatar
What do you have to do to the block to make it sustain those kind of crank hp numbers?
Is a 3.750 stroke the limit without moving the cam up?
Chris Anderson
Jan 27, 2015 08:30 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Jrlt1
Jan 3, 2015 07:38 PM
