buick roadmaster lt1
Re: buick roadmaster lt1
Originally Posted by iiibdsiil
Iron Headed and the cam is different.
The torque rating is a little higher at a little lower RPM and what most people neglect is that was achieved with grandpa quiet intake and exhaust as well as 87 octane so don't think it is that far behind the f-body motor. It was just setup for a different purpose.
The shortblock is identical.
Cam in a B-body is a lot smaller then an F-body, I'm positive that a b-body makes more power then an F-body with the same cam and even just an FIPK kit on both cars, this is cuz iron heads flow a lot more and although they are lower compression, iron keeps combusion heat in making more power, so unless you're taking the f-body heads to the max ie. porting and adding more compression, I think a b-body would make more HP, but you can't pull the compresson up much higher on an iron head like you can with alluminium.
guionM
69
Nov 30, 2006 02:01 PM
redzed
Aug 31, 2002 01:00 AM
