broken water pump or just a gasket?
Old Apr 24, 2003 | 12:00 PM
m0nk's Avatar
So as I was driving the other day I noticed the low coolant idiot light was on, and I dont understand why because I just checked the coolant and oil 3 days before. So when I park i noticed that coolant was dripping from the water pump. But it stopped after about 1/2 cup dripped out. I start the car back up and its fine, turn it off and it leeks another 1/2 cup.... apparently it only leaks when i turn the car off?
http://members.aol.com/atomicm0nk/images/waterpump.jpg
theres a picture of the leak.... Is it just a gasket or am i going to have to buy a new pump?
Old Apr 24, 2003 | 12:04 PM
NOMAD's Avatar
Cool
It's either the weep hole (which should be sealed now any way with an electric WP) or the seal between the electric pump and the housing. If it's a CSI, you may not have it notched correctly causing to not seal all the way.
And for the love of everything good, please shorten your sig to 5-7 lines
-Shannon
Old Apr 24, 2003 | 12:11 PM
Bryan Smith's Avatar
Remove your radiator cap. Turn on car. Do you see coolant flowing in a steady stream - if not test your pump could just be a loose connection. I'd still take off the housing and clean that up a bit and maybe reseal it just to be safe.
edit: nice car btw
Old Apr 24, 2003 | 02:01 PM
m0nk's Avatar
ok thanks for the help guys ill check it out when i get back from class... my sig is 6 lines... isnt it?
Old Apr 27, 2003 | 11:43 PM
m0nk's Avatar
ok so i found whare the actual leak is from, its coming from the hole on the bottom of the waterpump, there is one on the top also, coolant dosnt leak when car is running, but when i turn it off it does out of the hole, if i plug up the hole it comes out the hole on the top, its a meziere pump if that helps any. If i put water into my radiator when the car is off it comes out the holes still.
i updated the picture so the hole can be clearly seen.
the car seems to not have a problem staying cool as it stays at its normal 160 or lower. is there a problem with the internals of the pump, and if so can it be rebuilt or should i just buy a new one.
Old Apr 28, 2003 | 07:44 AM
No. Even at full screen, it's like 12. Forum rules limit the sig to 5 lines.
Old Apr 28, 2003 | 09:00 AM
johnpsz's Avatar
I count 14 and I got my resolution up pretty high with a nice size screen, What computer are you running that you think all that is on 6 lines, is it a 50" monitor? Just show the basics, you don't have to tell everything in there! I've been to you brothers web site I'm sure he has room on there for you to go into more detail about your ride.
Good luck with the Pump though.
Old Apr 28, 2003 | 12:54 PM
m0nk's Avatar
20" viewable w/ a 1600x1200 res.... i cut a bunch out now my computer shows 4....
Old Apr 28, 2003 | 08:25 PM
johnpsz's Avatar
1997 Camaro SS: 383ci w/ 8.3:1,cam 225/234.9 560/536 lift 114lsa,Pro Mag NSA 1.6 Rockers,Stage 2 Pro Performance Heads 62cc,2.00/1.57 Manley Race Valves,BBK 58mm TB,Aeromotive 1200HP Fuel Pump+Fuel Pressure Regulator,Sumped Fuel Tank,Siemens 72# lb. Injectors,Random Tech Adj Torque Arm,Mac Lower Control Arms,Mac Panhard Rod,Chassis Engineering SFC's,Solid Engine Mounts,Polley Trans Mount,LS1 Alum DriveShaft,3.42 Gears,17X11 AFS SS Rims ,315/35/17 555R Nittos,Spec Stage 3 Kevlar Clutch,LS1 Brake Upgrade Kit,Jet Hot Hooker LongTubes,3" duals w/ X-Pipe,160degree T-Stat,Meziere Electric Water Pump,OBD1 Computer & Knock Sensor,LT4 Knock Module,MSD 6AL Ignition
That is your sig might I suggest something like below, because there are a lot of people out there with smaller monitors and less resolution.
1997 Camaro SS: 383ci w/8.3:1,cam 225/234.9 560/536 lift 114lsa,1.6 Rockers,Stage 2 Heads w/62cc,2.00/1.57 Manley Race Valves,58mm TB,Sumped Fuel Tank,Siemens 72# lb. Injectors,Adj Torque Arm,Lower Control Arms,Panhard Rod,SFC's,Solid Engine Mounts,LS1 Alum DriveShaft,3.42 Gears,17X11 AFS SS Rims ,315/35/17 555R Nittos,Spec Stage 3 Kevlar Clutch,LS1 Brake Upgrade Kit,Jet Hot Hooker LongTubes,3" duals w/ X-Pipe,160* T-Stat,Meziere H2O Pump,OBD1 Computer & Knock Sensor,LT4 KM,MSD 6AL Ignition
That gets pretty much everything you wanted to show, or at least what most people would want to see. And, it would never hurt to leave people guessing sometimes.
Old Apr 28, 2003 | 11:10 PM
m0nk's Avatar
got it down to 3 lines , or is this still to much lol
so i pulled the pump and one of the o-rings broke, couldn't find a way to get it out so I used water pump gasket sealer... hopefully that works, if not is there a way to put new o-rings in these pumps or should I order a new one?
Old Apr 29, 2003 | 07:15 AM
johnpsz's Avatar
TTT for ya, I want to know also, thinking about getting the Water Pump as one of my next mods.
Old Apr 29, 2003 | 10:15 AM
m0nk's Avatar
well the gasket sealer worked, pumps not leaking anymore and my low coolant light stays off , but since i took the wrong side of the water pump off first I spent about 30 mins using pinsize allen keys trying to hold the pins in position while I slid them back over the shaft... stupid me for taking that side off in the first place
now I'm hooking up relays to the fans so I can shut them off while I program the car.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Jazsun
Dec 29, 2014 12:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
