broken rocker arm stud
Old Apr 30, 2003 | 08:14 AM
rocmemphis's Avatar
I was having a bad misfire and I checked and replaced all the cheap stuff first....wires, plugs, etc. Well I then replaced the Opti, waterpump, ICM, and fuel filter. Nothing worked my car was still misfiriing. So I pulled the valve covers and the intake rocker arm stud on the the #3 cylinder was broken right in half. That was a good $500 lesson
Anyone ever broken a rocker arm stud?
Old Apr 30, 2003 | 09:18 AM
96speed's Avatar
Question
Stock stud? Stock rocker?
Old Apr 30, 2003 | 09:39 AM
rocmemphis's Avatar
Stock stud...aftermarket 1.6 roller rocker...LT4 valve springs.
Old Apr 30, 2003 | 09:46 AM
94SLUG's Avatar
Yes had the same problem. Buy some good ARP/CRANE studs you should be fine. Take a look at the pushrod and rocker for damage. Make sure no metal hiding in there.
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
JCSWS6
Jul 19, 2015 06:47 PM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
94Form
Jul 17, 2015 10:56 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
