Broken Motor Mount Bolt
Old May 9, 2006 | 12:44 PM
Ekof96Z28's Avatar
Hey guys, Passenger side. The top right bolt that bolts the mount to the block is broken. Just picked up the engine from a salvage yard. Noticed there is a minor seperation to the right and left of the bolt as well in that little bung that it screws into.
Is this something to be concerned about? Or should I just drill the bitch out and put a new one in. I tried turning it out w/ vice grips but it just tore the threads off of what was sticking out.
Old May 9, 2006 | 02:16 PM
matt65's Avatar
Re: Broken Motor Mount Bolt
I would remove it and replace with a new one if it were me.
Old May 13, 2006 | 10:46 PM
Ekof96Z28's Avatar
Any suggestions for getting the damn thing out? I've been using 7 inch vice grips on it and all they do is slide around and rip the threads off of the bolt stickin out.
Old May 13, 2006 | 11:52 PM
Dave89IROC's Avatar
heat
if you don't have a torch, take it by a local shop, they should be able to pull it easy enough
Old May 14, 2006 | 12:08 AM
bstieboydp's Avatar
a nice little map or even propane tank will do the trick with enough force, if you still cant get it any shop can do it
Old May 15, 2006 | 08:57 PM
Ekof96Z28's Avatar
I tried it w/ a propane torch, my problem is I cannot get anything to grip onto it hard enough to do anythintg but slide around it.
Old May 15, 2006 | 09:00 PM
Dave89IROC's Avatar
how much is sticking out?
Ekof96Z28's Avatar
Would it be that bad to just go w/ 2 bolts instead of 3 on that side?
Old May 16, 2006 | 10:25 PM
leadfoot94's Avatar
I wouldn't; you want your mounts to be strong...You can try to drill it out by starting with a small drill-bit and working your way up until you leave just a "ring" of threads, then get an easy-out and back the "ring" out.
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
maybe2fast
Mar 16, 2015 09:45 AM
1LEThumper
Jul 14, 2003 12:45 PM
