Broken exhaust manifold studs
Old Jul 21, 2003 | 11:36 AM
PatriotTA's Avatar
OK, while removing the y-pipe I broke all 6 (yep all of them) studs that go between the manifold and y-pipe. I dropped the manifolds and tried to blowtorch them out, to no avail. Can I just grind them down and then drill them out, then re-tap the hole and install new studs? Does anyone know the part number for the studs, or how much they would be? Or would it just be easier getting new (used) manifolds?
Old Jul 21, 2003 | 11:41 AM
speed76demon's Avatar
time for headers no just joking modding doesnt fix anything believe me. What i did was grind them off then drill them out then i just dropped a bolt down in it screwed a nut on tight and i didnt even have the slightest leak
Old Jul 21, 2003 | 11:54 AM
PatriotTA's Avatar
You're saying you just dropped a bolt down from up top and put a not on the bottom, similar to the stock setup?? That sounds good to me. I wanted to do headers (it pisses me off doing this work just for the stock manifolds) but I don't have the cash right now. Probably next season. Thanks.
69z-28
Jan 29, 2016 10:46 PM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
spearous
Jan 12, 2015 11:03 AM
