Broken Bolt
Old Mar 19, 2010 | 06:12 PM
93_ZZZZ's Avatar
Broken Bolt
Alright when i bought this car i noticed an exhaust leak, it's the last bolt on the drivers side, it seems to be broken off in the head any ideas of removal without removing the engine?
There isn't a whole lot of space so i'm guessing engine removal is probably the only option unless the elders have a trick or tool?
Old Mar 19, 2010 | 06:18 PM
You wouldn't pull the whole engine, just that head.
Old Mar 19, 2010 | 06:24 PM
93_ZZZZ's Avatar
still a ton of work though.. =(
Old Mar 19, 2010 | 06:46 PM
Mswezey's Avatar
From: Wichita Falls, Texas - College. DF-Dub, when not in college
Better than pulling the engine....
Old Mar 19, 2010 | 10:37 PM
93_ZZZZ's Avatar
Well, it's kind of hard doin anything like that to your daily driver when you work 6-10 hour days a week...only day i have is sunday and if it doesn't get done, or done right then I don't have a ride monday... =( but not only is the ticking driving me crazy, i'm pretty sure it's throwing off my fuel ratio cuz i'm burning way to much gas...
Old Mar 19, 2010 | 10:58 PM
Peytons'z's Avatar
I'm going through the same thing right now. Same bolt is broke off. Mine is retarding timing like crazy (false knock). It will only get worse trust me. You have two options to "fix" it. Remove the head to extract the broken bolt or upgrade to headers. I know for sure that lpp longtubes do not reuse that bolt so just grind it flush. Neither fix is easy though and it might not be possible for you to do in one day.
Old Mar 21, 2010 | 12:02 AM
Dave1980's Avatar
I would do the headers.
Old Apr 2, 2010 | 10:01 AM
93_ZZZZ's Avatar
You say it doesn't reuse that bolt but in the pictures it looks as if it has a spot for a bolt to hold them on? Just kinda curious about it. http://lpparts.com/store/page6.html
Old Apr 2, 2010 | 10:55 AM
Z28SORR's Avatar
Isn't it always?
It 's called renting a car!! You should at least pull the exhaust manifold and see if any of the bolt is accessable. You might get lucky.
Old Apr 2, 2010 | 11:39 AM
Peytons'z's Avatar
Positive they don't use that bolt. There is another bolt hole closer to the exhast port they use that is covered by the stock manifold. I installed mine last week.
Old Apr 2, 2010 | 01:14 PM
93_ZZZZ's Avatar
thanks alot! have you figured out your timing issue?
Old Apr 2, 2010 | 08:43 PM
Peytons'z's Avatar
Not yet, but getting close I think. It's no where as bad as it was.
Old Apr 3, 2010 | 06:52 PM
93_ZZZZ's Avatar
Good, I'm still having ignition issues, i changed coil, wires and plugs, and i can still see blue electricity moving around my coil and in the wire but all my plug wires look fine I'm at a loss. I'm guessing the opti is messing up but doesn't sound near as bad as your timing
maybe2fast
Mar 16, 2015 09:45 AM
FredM
Mar 6, 2015 03:04 PM
Red_94Formula
Parts Wanted
Dec 6, 2014 11:07 PM
1LEThumper
Jul 14, 2003 12:45 PM
