Broke/bent ALL 16 pushrods
Old Oct 18, 2003 | 03:56 PM
  #16
12SCNDZ's Avatar
I don't think valvesprings are your problem. Did you adjust the valves with the motor running?...If not, you probably had them too tight.
Are you sure the cam/crank phasing is right? Did you line up the dots on the crank and cam?...Cam at 6 o'clock/crank at 12 o'clock.
Frank
Old Oct 18, 2003 | 03:59 PM
  #17
brandboZ28's Avatar
Yep, dot to dot
Old Oct 18, 2003 | 04:09 PM
  #18
turbo_Z's Avatar
im sure you know either the valves are extremely tight or the springs are coil binding to bend all 16 pushrods.
  #19
OldSStroker's Avatar
Originally posted by brandboZ28
Yep, dot to dot
With #1 piston at TDC, right?
Old Oct 18, 2003 | 04:14 PM
  #20
brandboZ28's Avatar
Yeppers
Old Oct 18, 2003 | 04:29 PM
  #21
DDZ/28's Avatar
Double check with Shoebox, but I believe cam dot @ 6, crank @ 12 & cam dowel @ 3 is # 6 TDC.
Might make a difference...
Old Oct 18, 2003 | 07:43 PM
  #22
brandboZ28's Avatar
You are exactly right. I said that wrong, its been a long couple of days. I did it dot to dot. Cam dot @ 6 and crank dot @ 12 with cam dowel pin at 3.
Old Oct 18, 2003 | 08:59 PM
  #23
97Camaro007's Avatar
Dude sorry to hear about your luck.....I have done the same thing but i didn't adjust the rockers right and it bent a couple of them....good luck
Old Oct 18, 2003 | 10:02 PM
  #24
Another thought is that I hear the Comp R lifters use very little lash. That means that the effective lift is a little more than with a standard lifter (won't be much, but a little). If the previous owner was not using Comp R's, maybe that is the difference. Check for coil bind as already suggested.
Old Oct 19, 2003 | 07:41 AM
  #25
brandboZ28's Avatar
Someone on another board mentioned something about the LT1 being a non-interference engine. Is this true and if so, should I pull the heads anyways to check for valve kisses on the piston just incase? Thanks guys.
Old Oct 19, 2003 | 07:54 AM
  #26
I think you mean interference (which it is), not the opposite. It depends on what caused your pushrods to bend in the first place. If there was that much contact, valve to piston, I would think you would hear it. If you can't figure out any other reason, pulling a head might be a good idea.
Old Oct 19, 2003 | 07:59 AM
  #27
brandboZ28's Avatar
Heres a quick vid that my buddy made of the short time that the car ran. Sounds pretty nasty if you ask me. Lets just say I plan on yaking the heads after listening
Right Click, Save As
http://www.dragtruk.com/PICS/C1OHH07GWOA81.mpg
Old Oct 19, 2003 | 08:04 AM
  #28
SWINGRRR's Avatar
Sorry to hear about the luck.
Did you ever get the black rims on? Pics?
Old Oct 19, 2003 | 08:07 AM
  #29
brandboZ28's Avatar
Hey, nah, just about the time I bought the rims, a friend of mine offered me a killer deal on the cam and springs that I just "installed" on my car so I never got them on. A buddy of mine was kinda in a bind and needed some rims so I let him have them. They are on a red Z28 with black stripes-VERY SHARP!
Old Oct 19, 2003 | 08:42 AM
  #30
I think I would look at the cam and crank sprockets, first and then pull the heads if you wanted to inspect.
