breslin header bolts
Old Jun 28, 2006 | 01:14 PM
onetransam4u2nv's Avatar
I have leaky pacesetter long tubes I'm lookin to buy some breslin header bolts anyone useing these know the part number i need or the correct size.
Old Jun 28, 2006 | 01:24 PM
NVetro's Avatar
Re: breslin header bolts
http://www.go-breslin.com/
call up and tell them the year of your car and they will offer you the 3/4" and the 1", make sure to get the 1" bolts! They rock, i just put them on.
Old Jun 28, 2006 | 01:26 PM
BUBBA's Avatar
What are you currently using for fasteners? I.e, are you implying that your headers are leaking because of the bolts? Just curious.
thx
Old Jun 28, 2006 | 01:36 PM
no implying that my current fasteners backed off causeing them to blow out. so im going with pery's dead soft blow proof gaskets and breslins.
Old Jun 28, 2006 | 06:00 PM
96SSM6's Avatar
Same gasket and bolt combo Ive used on three LT1s. All three cars are leak free and the bolts havent been touched after the install.
Old Jun 28, 2006 | 08:56 PM
TobyZ28's Avatar
P/N 600-101 - Have the box infront of me right now
These are 12:3/8" - 16x1" Locking bolts.
Old Jun 28, 2006 | 09:49 PM
stereomandan's Avatar
My header bolts never backed out, and I have the standard ones that came with my MAC's. I don't believe much in the locking bolts. If you retorque the standard bolts every day for a week or so, you'll be o.k. I also used the Mr. Gasket Ultra seal gaskets, which are very similar to the Felpro's. I did have problems with the copper gaskets however, they had very small leaks.
Dan
Old Jun 29, 2006 | 06:36 AM
why not buy the lockers and set and forget about it. i don't wanna tighten them up every week or so. this car takes up enough of my time.(dam hobbies)
Old Jun 29, 2006 | 11:31 AM
You only check to see if they need to be retightened the first week. I haven't touched mine in over two years.
Dan
Old Jun 29, 2006 | 01:48 PM
user 647483's Avatar
I've never seen those before, looks like a great design
Much better than the 3-peice stage-8 locking bolts I have now.
Old Jun 29, 2006 | 02:56 PM
1racerdude's Avatar
If ya don't get the stainless,take out the locking screw on all of them and put a small dab of anti-seize on them to insure they will unlock when ya want to take them out or re tighten.
Old Jun 29, 2006 | 04:47 PM
truedualws6's Avatar
Great comment. I was thinking of putting a dab of anti-sieze on the SS
locking screws as well. It sure can't hurt anything.
Old Jun 29, 2006 | 04:55 PM
TobyZ28's Avatar
Just curious - why wouldn't you put antisieze on the stainless ones? Does it react in some way with stainless steel?
Old Jun 29, 2006 | 05:58 PM
Kevin Blown 95 TA's Avatar
They don't unscrew themselves, the gaskets compress from heat cycling and the bolts probably stretch a little, too. You should count on having to retighten them a couple times, then lock them down if you want.
And some of those copper gaskets are shaped wrong for the headers in that the header openings might cross over the boss in the lower portion of the gasket and have a built-in leak on all 8.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
